The lighter ones like RPS Sport and JWT Street normally work fine with the stock pedal adjustment. If you find your clutch grabs too close to the floor you will want get more pedal travel by doing the adjustment. Something to keep in mind is that if your just barely releasing enough, you will have a problem when everything heats up and expands. It requires about a half inch more of pedal travel to release a hot clutch and flywheel compaired to a cold assembly.
